08-27-2008 02:20 PM
We just bought a PXI system with a NI-PXI-1050 chassis. It contains 1 PXI-6704 AO, 1 PXI-6221 AI and an attched SCXI chassis containing 2 SCXI-1102B. Our linux system communicated with the PXI-1050 chassis via a MXI-4 module. We installed the NIDAQmx driver in our Linux computer and we were able to scan the PXI-6221 AI board using the example code in /usr/local/natinst/nidaqmx/examples/ansi_c/AnalogIn/MeasureVoltage/ConAcq-IntClk. However, our goal is to scan the signal through the SCXI-1102B via the PXI-6221 AI. But we were not able to find any example code about how to program the SCXI-1102B so that it will route its MUX output into the PXI-6221 input for data scanning. Could you send us an ansi C example on how to to the following:
- how to set the Gain and Filter options on the SCXI-1102B using ansi C programming
- how to route the output of the SCXI-1102B to the input of PXI-6221 using ansi C programming
- how to set the PXI-6221 to scan the signal from the SCXI-1102B
We are expecting to scan the these analog input at 1000Hz
We need a solution very urgent, because our customer is waiting for the answer to make the decision on continue using NI-PXI IO or not
My new email address is michael.lam@horiba.com. I tried to update it in my profile, but it failed every time. Could you update it for me too. Thank you very much for your help.
Michael
08-29-2008 08:20 AM
