Multifunction DAQ
PXI-6225 failures in common 4 channel differential inputs
I have a PXI-6225.  ACH differential paired channels 7/39, 8/40, 9/41 and 10/42 have failed and read 0 volts when 15 volts applied.  I would like to know if these four channels are sourced by one common IC chip.  This would explain the failure mode of four simutaneous channels failing at the same time.
(2,687 Views)
7/39, 8/40, 9/41 and 10/42 are not correct differential channels. 7/15, 8/16, 9/17 and 10/18 are.
(2,676 Views)
