I have a PXI-6225. ACH differential paired channels 7/39, 8/40, 9/41 and 10/42 have failed and read 0 volts when 15 volts applied. I would like to know if these four channels are sourced by one common IC chip. This would explain the failure mode of four simutaneous channels failing at the same time.
