12-09-2016 06:55 PM
I don't believe there's a solution for this but I'll ask anyway..
I use DAQmx logging (PXI-6281) to offload as much as I can CPU wise, instead of manually logging. This was the easiest way to approach my needs.
But I also want to acquire data while not logging (So the users can preview the realtime data).
So, I currently use two tasks:
I then switch between these tasks when the user wants to start logging. The start trigger is either externally supplied or internally generated.
Works fine.... extept now I have a need to prevent any disruptions in the preview data stream when switching back and forth between preview and acquisition modes. This means I need to use a single always running task.
So, can DAQmx logging be enabled and disabled concurrent with a trigger?
The Pause Logging feature doesn't seem to function that way. In Read and log mode, pause logging can only start logging on the NEXT read. That wont catch the samples between my trigger signal and the point I try to read samples. Two thoughts come to mind then:
XL600
12-12-2016 01:27 PM
Hi xl600,
Is your trigger source from a physical event that happens in hardware or is it just a way to enable logging? You could try specifying a number of pretrigger samples which are saved in memory previous to the triggering event. The number of pretrigger samples saved in memory can be configured as a property in the DAQmx Triggering Property Node. With that said, the Pause Logging functionality is worth looking into further:
http://forums.ni.com/t5/Example-Program-Drafts/TDMS-Logging-with-Pause-Logging/ta-p/3525697
You could also try switching between both tasks using the architecture presented here:
http://www.ni.com/example/28586/en/
12-12-2016 01:42 PM
It's either a software trigger or hardware (External trigger) depending on user selection. So I can't assume anything about it other than 'it will happen sometime'. This can be microseconds of delay (Self triggered) to minutes of delay (Hardware trigger) and anywhere in between.
The basic issue is that I don't want to suffer any missing samples or gaps in my preview data flow while wanting to ensure logged samples are logged from the trigger edge itself. My current design does suffer a gap (I am actually using that architecture) in both samples lost during switching the tasks and in the delay to the start logging trigger after switching to the logging task.
For pause logging, will the logged waveforms have a T0 of when pause logging was disabled or a T0 of when the task started and sampling began? I have a funny feeling it'll be the later situation.
XL600
12-13-2016 09:44 AM
Hi xl600,
The best way to achieve this functionality (more-or-less) is probably to use conditional logging based on incoming data values or a front-panel button which enables logging. Since a trigger tells your hardware when to acquire data and you'll be acquiring data throughout the entire program execution - but only logging sometimes - you'll have to use one of the above methods rather than the trigger to enable logging.
12-16-2016 05:25 PM
I spent all day yesterday working on this, but I think I figured out a way to handle this.
I already had a method for creating a timestamp notifier based on a PXI trigger (Using the DAQmx Create Timing Source VI and a real time timed loop). This timestamp is quite accurate (About 10us accuracy even under load).
All the while, I'm using all samples for my previewer function
The queue then gets emptied into my TDMS file.
I've tested this extensively today and I haven't seen a hiccup. I suspect things won't be so clean at sampling rates > about 10kHz since my trigger detector accuracy isn't all that good. But I don't collect at higher rates so it doesn't matter.
Performance wise, this does add a few % CPU when I'm manually logging 16 10kHz Ain channels. I can live with that.
