01-15-2019 10:19 AM
We would like to buy a cDAQ system to log automotive transmission sensors while driving a car. What is the best way to power the cDAQ-9178 chassis during automotive testing? Can we simply wire chassis to the 12VDC outlet in a car, or does the battery voltage need to be conditioned? Does the earth ground of the chassis needed to be connected to the frame of the car (battery ground) as well?
01-15-2019 11:15 AM
The 12V outlet should work just fine. If you really want, you could add a capacitor between the +12V and RTN lines to add some filtering. But I wouldn't worry too much unless you really have some sensitive measurements to take.
02-15-2019 03:14 PM
Should I connect the frame ground on the cDAQ to the frame ground of the car?
02-18-2019 01:40 PM
Yes, I'd assume you'd want your ground references to be the same to ensure that your signal is 12V above the common reference.
