07-08-2010 01:08 PM
I am trying to install the software for a NI-DAQmx on 64-bit Windows XP. Shortly into the installations, I get an error that says "The 64-bit IVI Shared Components require Windows Vista or higher." I am able to click continue, and the installation goes on and seems to be working, but at the end, it says that the installation failed. I receive error messages a couple more times during the process like "The NI SCXI for 64 Bit Windows 1.11.0 installation has failed," and then it tells me that the installation has failed. I have tried using the CD that came with the hardware and downloading straight from the website, and both gave the same errors. Are there any solutions to this?
Tim
07-08-2010 02:50 PM
DAQmx is not supported on 64-bit XP-- only 32-bit XP is supported; if you need to use a 64-bit operating system with DAQmx, you'll have to use Vista or Windows 7.
See also:
What National Instruments Products are Compatible with the 64-bit Windows XP x64 Operating System?
