06-04-2014 03:13 PM - edited 06-04-2014 03:17 PM
After connecting a different prototyping board to the Elvis, the power for the prototyping board has stopped working on the Elvis. Even when I reconnect the NI Elvis Series Prototyping Board to the Elvis it will not work. The LED in the upper right corner of the board won't even light up indicating that it's sending power to the board. Although the USB Active LED will light up still when the board is turned on.
I have checked and replaced the fuse for the Elvis and it still does not work. I hvae also tried different prototyping boards, but the problem seems to lie within the Elvis itself.
Any ideas as to what could be causing this problem and how I might go about fixing it?
Solved! Go to Solution.
06-05-2014 09:52 AM
Are both power switches on? I recall someone else had this issue-
See the manual:
http://www.ni.com/pdf/manuals/374628c.pdf
-AK2DM
06-05-2014 10:53 AM
cgc47,
As mentioned by AnalogKid2Digi..., the first thing that we need to make sure is that you have both power switches ON. Once both of this power switches are ON, are the three LEDs corresponding to the +15V, -15V and +5V DC power supply on the left side of the Elvis protoboard ON?
Warm Regards,
William Fernandez
Applications Engineering
06-05-2014 12:20 PM
When the power switches are both on, onle the USB Active light turns on
06-05-2014 05:31 PM
cgc47,
Please call at 866-ASK-MYNI (866-275-6964) and one of our applications engineers will help you troubleshoot the unit and possibly process an RMA.
Warm Regards,
William Fernandez
06-06-2014 08:18 AM
It's working now. We opened up the board to try and test it, and during the process it reset itself and now works. Thank you all for the responses!
04-24-2018 04:43 AM
Same problem happened to my ni elvis ii i dont know now what to do?
Can u please guide me?
04-25-2018 03:18 PM
Hi tnoor,
This thread is four years old so it probably won't be seen by many people. I suggest you create a new thread so that more people can see your question.
Misbah
