Multifunction DAQ
Read power levels of external power supply to 9411 card
My environment:
9174 DAQ
9411 module with external power supply
5V encoder powered through the card output
Python using nidaqmx
I can read pulse changes from the encoder just fine.
My question here is if I am able to monitor the input power to the card that is then supplying it to the encoder or if I should (or can) read the power level on the output pin on the card.
-Evan-
(1,043 Views)
If you mean the power supply at VSUP terminal of 9411 - not by itself, you can feed this into analog input of another c-series module to monitor.
9411 does not have the means to measure/monitor the VSUP terminal.
Santhosh
Soliton Technologies
(1,030 Views)
Indeed, that is what I meant -- perhaps I can read the value of output pin that supplies the power to the encoder?
-Evan-
(1,018 Views)
You can do either way, monitor the 5V pin or the raw VSUP pin.
Santhosh
(1,015 Views)
