Multifunction DAQ
Reading values from input channel in bnc 2110
I hope you are not using the previously discussed method for doing such a long acquisition? That is not at all appropriate, imho. What is your sample rate?
Message Edited by Dennis Knutson on 07-24-2009 03:32 PM
Message 21 of 23
(1,428 Views)
Hi Dennis
Nope i have changed the vi as u mentioned. I entered multiple channels in the single physical channel control. I have chosen 50 samples and 50 000 Samples per second. so the acquisition takes 0.001 sec.
Nghtcwrlr
Message 22 of 23
(1,407 Views)
Hi Dennis,
Sorry to disturb you. Now I have 2 analogue trigger sources and I want to use the BNC-2110 to convert them to digital sources and trigger 2 measurements to start. The thing is I can't use the Analogue Input channel as it only allows one daq assistant to work at one time. And if I sample these 2 sources by one DAQ assistant, the signals are mixed and I don't know how to seperate the 2 signals. Do you know how should I do this?
Thanks very much!
Henry
Message 23 of 23
(879 Views)
