01-11-2019 01:20 PM
Hello Everyone,
We are looking to buy a DAQ unit and have narrowed it down to selecting USB 6343 BNC or the screw connector. As per the images on the website BNC verson of the unit comes with a BNC control block and the screw version of the unit doesn't. I just wanted to confirm whether my understanding is correct.
Also, does anyone know what all inbox accessories are included along with the main DAQ unit. I especially wanted to know will the BNC cables would be included or not.If then which type of cables would be needed.
Link for Screw Version
Link for BNC Version
Thanks & Regards,
Chinmay Swami
01-14-2019 04:54 PM
Hi ChinmayS,
The image can be a little deceiving. The BNC control block is actually apart of the USB 6343 so there is just the one device and therefore doesn't require a cable to connect the two. You will still need to purchase a power cord.
Hope this helps!
