09-21-2007 04:41 PM
09-25-2007 12:21 AM
What error specifically do you receive with the SCXI 1001 chassis? Please include error code and message.
09-25-2007 11:41 AM
09-26-2007 10:02 AM
09-26-2007 04:10 PM
09-26-2007 04:46 PM
09-28-2007 06:14 AM
Hi Adam,
From my understanding you are only getting incorrect readings from your SCXI 1102 modules in the SCXI 1001 chassis. I did take a look at the drawing of your setup. I am not sure if your setup could be causing this because they are not quite daisy chained together. Have you tried the SCXI 1102 in a single SCXI 1001 chassis outside of the setup? Do you always use the SCXI 1102 in the first slot of the chassis? Check out this Knowledge Base. I would also recommend you take a look at these knowledge base articles found here and here.
10-13-2007 11:40 AM
10-15-2007 11:37 AM
Hi Adam,
You are welcome for the help. I am glad that the issue is being resolved. Thank you for listing out the cause of the problem. It always benefits others who view this post. Are you getting your 1346 replaced?
03-24-2008 04:50 PM
