SMU vs. DAQ
Hello to everyone,
thanks in advance for all you can suggest to me.
I am wondering about the purchase of 2 SMUs vs. DAQ.
What is the real advantages of using a SMU instead of a multifunction data acquisition ?
(I have seen for example the NI X series Multifunction data acquisition systems).
G.
(3,576 Views)
They are two completely different types of equipment.  An SMU is a Source Measuring Unit.  You can think of it as a very precise power supply.  A DAQ is a Data Acquisition.  It only reads voltage, usually in many channels at a time.
So the real question is what are you trying to do?
GCentral
(3,569 Views)
Hi
(3,536 Views)
Accepted by topic author pogor
The problem you might have with the analog outputs of a DAQ is that they have a really small current limit.  I would use 2 SMUs for my input and a DMM to measure the output.  I am sure you can find an SMU with a lot lower voltage range.  Just a quick look and I see a PXIe-4144, which has 4 outputs at 6V, 500mA.  So I would go with that and a PXIe-4081 DMM.
GCentral
(3,531 Views)
Hi again Crossrulz, and thanks for the suggestion, that looks very very great...
It seems a very good solution...
G.
(3,506 Views)
