Scan lists for splitting sampling intervals on PCIe-6363?
I'm trying to set up a data acquisition task on a PCIe-6363 to get data from three analog signals. The first signal needs a sampling rate of 1 Ms/s, whereas 500 ks/s would be sufficient for the other two. Sampling all three at 1 Ms/s exceeds the board's capability. The board is able to sample two channels at 1 Ms/s, but not three.
I came across some discussions of using scan lists, which define the order by which channels are sampled. Would it be possible to set up a scan list on this board that achieves the above, by sampling in the order CH1,CH2,CH1,CH3,CH1,CH2,CH1,CH3, etc...? Here, channel 1 would be sampled at twice the rate of channels 2 and 3. If so, what would be the string to set up such a scan list?
Many thanks for your help!
(945 Views)
This *used* to be possible.  But the capability was taken away sometime after DAQmx 16.0
I don't know why and registered my own complaint / request here.
(I only tested with X-series hardware like yours.  It's conceivable that M-series or other AI devices might still support it.  But I kinda doubt it.)
-Kevin P
ALERT! LabVIEW's subscription-only policy coming to an end (finally!). Permanent license pricing remains WIP. Tread carefully.
(935 Views)
Maybe it is still possible with Read Multiple Channels Sequentially Using DAQmx?
However, NI 6363 has the sampling rate of 2MS/s for single channel and 1MS/s aggregate for multichannel. Most likely you can only do 500kS/s + 250kS/s + 250kS/s.
Control Lead | Intelline Inc
(930 Views)
Thanks! Alternatively I may go with a second board. I noticed that while the PCIe-6363 allows the measurement at an aggregate of 2 Ms/s even when using multiple channels, it gives a warning that the settling time is violated and the accuracy might be compromised. It's probably better if I don't use it at the rate outside of specs. It would still be useful to be able to configure the channel switching with the scan list, a shame that ability was removed.
(907 Views)
Unfortunately, I don't think so, at least not for X-series that I did some testing on.  The referenced example was written back in 2009.  Back then DAQmx still supported repetition of a channel in a scan list.  Well, at least for multiplexing boards, which was what I habitually used.   (Also, the focus of the example is on controlling the convert clock rate to force non-default multiplexer switching intervals.)
But if anyone can demonstrate otherwise, that'd be good news!  Post here and also rebut the Idea Exchange entry I linked to.
-Kevin P
(883 Views)
