03-12-2010 11:18 AM
Good day,
while I filed a support ticket, perhaps the excellent folks on the forums have an answer to my
question as well.
I am using an NI 6010 multifunction DAQ, and am having a difficult time setting the output voltage.
I am running on OpenSuse 11.1, with nikal 110 and daqmx801f. Ah, I should also mention I
am using the direct C interface, and not running through labview proper.
Reading voltages through the DAQ is working well, but setting the output voltage with:
DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-5.0,5.0,DAQmx_Val_Volts,"")
DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL)
Is not working. I have a volt meter set up on pins 12 and 11 (12 being the ao0+ side and 11 being the ao0- side)
and am reading no output voltage. This is basically the same code as the NI example VoltUpdate.c, which
I am using for testing purposes while trying to get to the root of this issue.
Does anyone have any suggestions?
Thanks in advance.
03-16-2010 10:00 AM
It could be possible your card may be broken. Try running this and see if it passes the test. You would need windows machine for that 😉 and DAQmx driver.
Good luck !
