Multifunction DAQ
Some thing about Digital U8 1Chan 1Samp
Hi
I am amazied with the sample and channel
just like PCIe6537,   it is 32 channels with per-channel directional control.
i want to use the 32 channels all, and  continue to collect data.So should i chose "Digital U32 NChan 1Samp" or "Digital U32 1Chan 1Samp"
I think the two channels maybe have different means. in "Digital U32 1Chan 1Samp" the 1 channel may have 32 lines, and this 'line' is the same mena as the 'channel ' in PCIE6537's 32 channels.
Please help me
thanks!
(3,676 Views)
It depends on what you choose when you use the DAQmx Create Channel. When you use the polymorphic type for Digital Input, one of the inputs is line grouping. Over there, you can select 'one channel for each line' or 'one channel for all lines'. And, that will help you pick the polymorphic type for DAQmx Read.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,664 Views)
hi Adnan Z , Thanks very much.
if i use"Digital U32  1chan 1 samp" and set to "one channel for one line" then can i get 32bit data for one instance? if i can get,why are there 32bits?
in the line there are bit datas, for one sample i think it is only 1 bit, and there is only a line, so i should get 1 bit fore one instance.
where is the problem?
thanks !
(3,641 Views)
No, if you were to use one channel for each line and selected multiple lines, you would get an error if you used 1Chan 1Samp. You would have to use NChan 1Samp.
(3,638 Views)
