09-04-2008 05:44 PM
My setup includes a PCI-6035E card, a SCXI-1000 chassis and a SCXI-1520 module. The NI-DAQmx version is 7.4.0f0. I am trying to read a sensor with a voltage output of 2 to 6 volts. I have verified with a fluke meter that the output is 2 volts. The sensor has a signal HI(+) and a signal LO(-) which I have connected to S+ and S- of a channel in the 1520. This application is setup using Traditional NI-DAQ configurations.
When I look at the test panel for the appropiate channel i get the correct voltage but when I run a test on the Traditional channel I get an out of range red light. I duplicated the problem using a battery with a known voltage.
Can someone tell me what I am doing wrong?
Thanks in advance.
09-05-2008 07:00 PM
