09-13-2011 04:47 PM
I have a couple of legacy AT-AO-10 that we're migrating to a new computer (upgarding to latest hardware). Though when I try to test the resources in MAX I get a pop-up stating "The device is not responding to the first DMA channel." Any suggestions?
Thank you
09-14-2011 07:21 PM
Hi lupinal,
What version of MAX are you using?
Josh Brown
09-15-2011 09:40 AM
I'm running version 4.4.1.49152. Would a later version get me up and running?
09-16-2011 08:46 AM
Hi lupinal,
I looked into the DAQ issue and I believe that your drivers are fine. You said you moved to a new computer. I found this knowledge based article that is for another legacy device NI AT-MIO-16. For this board it seems that it is not compatible with faster bus speeds.
http://digital.ni.com/public.nsf/allkb/37E5485F053317C4862567BA005F2C05?OpenDocument
I wonder if there is a similar issue for the AT-A0-10. What was the bus speed of your old computer?
Josh Brown
