Multifunction DAQ
The device is not responding to the first DMA channel
I have a couple of legacy AT-AO-10 that we're migrating to a new computer (upgarding to latest hardware).  Though when I try to test the resources in MAX I get a pop-up stating "The device is not responding to the first DMA channel."  Any suggestions?
Thank you
(2,862 Views)
Hi lupinal,
What version of MAX are you using?
Josh Brown
(2,835 Views)
I'm running version 4.4.1.49152.  Would a later version get me up and running?
(2,831 Views)
Hi lupinal,
I looked into the DAQ issue and I believe that your drivers are fine. You said you moved to a new computer. I found this knowledge based article that is for another legacy device NI AT-MIO-16. For this board it seems that it is not compatible with faster bus speeds.
http://digital.ni.com/public.nsf/allkb/37E5485F053317C4862567BA005F2C05?OpenDocument
I wonder if there is a similar issue for the AT-A0-10. What was the bus speed of your old computer?
Josh Brown
(2,825 Views)
