Multifunction DAQ
The max. sample clock rate of PCI-6251 analog output??
I have a problem of setting PCI-6251 analog output sample clock rate. I tried many setting of sample rate, from 10 kHz to 1 MHz. If the sample rate is less than 33 kHz, the output signal (1 kHz square wave) measured by oscilloscope is OK. If the sample rate is larger than 33 kHz, there is a problem. The output signal becomes DC 5 V. I check the max. sample rate in PCI-6251 specification note. The max. sample rate (updating rate) is 2.86 MHz. The target of my application is that the time step between each sample must be less than 50 us. I tried to find some information om internet, but I cannot find anything about this. The sample clock which I used is on board clock. If someone have some suggstion, please answer this post. Thank you.
(3,194 Views)
您好:
我懷疑卡片故障,請先下載以下軟體測試。
http://joule.ni.com/nidu/cds/view/p/id/566/lang/en
cable 請先拔除,請確認DAQ driver版本。
如果故障請致電NI客服部,02-2377-2222
(3,178 Views)
