02-07-2007 06:52 PM
02-08-2007 06:57 PM
02-09-2007 03:48 AM
There is a 5 second delay at startup before making DAQ (Traditional or DAQmx). The DAQmx works fine as does the rest of application (TCP, UDP, queued state machine, etc.). The Traditional DAQ init calls work as expected, only getting an error on AI Read.
There are no references to any front panel controls.
Also, I am not referencing same HW with both DAQ drivers. All AI is through Traditional and all AO and DIO (all separate cards) through DAQmx
02-09-2007 11:00 AM
02-09-2007 02:39 PM
I am using DAQmx create Channel as the first call. Does Traditional NI-DAQ have the same issues (since error is AI Read and that chain)?
Thanks.
02-12-2007 01:17 PM
02-12-2007 01:56 PM
