02-05-2025 11:12 AM - edited 02-05-2025 11:14 AM
02-05-2025 12:42 PM
This is called streaming, and in terms of DAQ, you need to continuously read in chunks of 100ms of the sample (rule of thumb). The good thing is that DAQ implements DMA, thereby it can directly write to computer memory locations.
In general, streaming 3 AI channels at 5kHz is not a challenging task at all. Please share your code to ensure you're following the best practices.
02-07-2025 02:06 PM
Hello Santhosh,
Thank you for your response. Would this vi be able to read every sample at 5kHz?
02-07-2025 06:30 PM - edited 02-07-2025 06:31 PM
Your implementation cannot keep up as you're reading 1 sample at a time which is too slow.
If you just need to collect the data, FlexLogger will make your life easy as it is configuration based data acquisition.
02-10-2025 10:48 AM
It is explaining the real-time constraints in a streaming case with examples in python and VI,. where you process data live through callbacks.
As mentioned by santo_13, if you just need the samples, there are better ways.
For example, I process measurements live to display them on a screen. And I also use APIs to acquire data and post-process later, thus I don't need callbacks in that case
02-13-2025 12:05 PM
Hello Santosh and ft,
The Daqmx maxes out at 1000 samples with this program. Is this the buffer limit?
Alex
02-13-2025 05:12 PM
Alex
It is not a limit, but rather, you left some inputs to the DAQmx Timing VI unwired, letting it go with the default values of 1000 finite samples.
Now, all that you need to do is change Finite Samples to Continuous Samples and the 1000 wouldn't matter and DAQmx will automatically size the buffer based on the number of samples you wire to DAQmx Read.
02-14-2025 02:42 AM
I can't really help for Labview but the concepts are the same between Labview, C API and python API. As various people highlighted, the principles are (I just summarize, I let you draw the decision tree 😉 😞
- use finite acquisition if you just want samples at the end and no live post-processing, there is some wire to change the number of samples. 1000 samples may be a generic default config for all devices or what the onboard buffer size allows you before having to dump on host (generally onboard buffer is like 2K, 4K, ... so same order of magnitude then 1000 samples)
- if you want huge number of samples, framework may disagree allocating too big host buffer then you switch to CONTINUOUS mode and you stop it when time has elapsed. In finite or continuous cases, framework can take care of the copies between onboard buffer and host buffer and storage on disk
- you don't have high-rate acquisition so you can let framework decide the buffer size on your host. If you have specific load constraints on your host (for example I display data live), you can tune it, there should be some input_buffer_size property somewhere in Labview
