USB 4431
I would like to measure vibration in the range of 5-500Hz. Can I use USB 4431 with the appropriate sensors.
Message 1 of 8
(2,161 Views)
You could use it with some work.
I would suggest that you Google the specs of the 4431. If you do so, you will find that the minimum sampling rate is 1000 Sa/s. So you will need to do some data processing with the acquired signal to have a rate between 5 - 500 Sa/s. You can take the mean, median, max, min, etc.
mcduff
Message 2 of 8
(2,146 Views)
Dear mcduff,
First of all I need to tell you that I am not an electrical person. So my understanding of electrical instruments is very minimum.
1. If I used sampling rate greater than 1000Sa/s, do I still need to do post-processing on the signal of 5-500Sa/s? I have been using DAQ 6289, and there was no post-processing required.
2. Is this USB 4431 compatible with geophones adapted with BNC connectors?
3. How do I protect the USB 4431 in areas of heavy electrical interference/noise? Is there a way to ground the equipment?
4. Is it possible that I try out the USB 4431 with my geophone before I decide to purchase it for my personnel research related to measurement of vibration in the ground?
Regards
Message 3 of 8
(2,091 Views)
Not sure I understand your question. The minimum sampling rate for the 4431 is 1000 Samples/s; if you want less than 1000 samples per second, you will need to do post processing. If the extra data doesn't bother you then you don't need to do anything.
I have no idea. The 4431 is an IEPE enabled 24 bit digitizer. The 4431 can output ~2 mA of DC current to excite an IEPE sensor. I know nothing about your geophone.
There is a grounding pin in the back. Shielding and grounding is site specific, so I cannot answer your question.
You can talk to your NI Rep.
mcduff
Message 4 of 8
(2,078 Views)
Thank you
Message 5 of 8
(1,731 Views)
Hi mcduff ,
May 4431 work with a external sampling clock?
Or is there a USB multifunction card that have a 24 bit resolution and may work with external sampling clock?
Best Regards. Have a nice day.
Zhang ming
Message 6 of 8
(1,345 Views)
@zhm0204 wrote:
Hi mcduff ,
Zhang ming
Some USB cards have PFI inputs that allow one to use an external sampling clock. The 4431 has PFI inputs in the back on the 9 pin connector; no idea if they support an input for an external clock. As far as other cards goes, the NI website has all the information; I do not know of any model offhand.
Message 7 of 8
(1,334 Views)
@zhm0204 wrote:
Hi mcduff ,
Zhang ming
Unfortunately, No, Delta-Sigma modulators in DSA cards cannot take an external sampling clock as the clock has to be continuously running in order to work.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OVZSA2&l=en-US
https://www.ni.com/en-us/innovations/white-papers/10/benefits-of-delta-sigma-analog-to-digital-conve...
Santhosh
Soliton Technologies
Message 8 of 8
(1,256 Views)
