06-10-2010 09:40 AM
06-10-2010 10:51 PM
I believe you may need NI-FGEN VI's. See this example which changes an arbitray waveform on the fly in LabVIEW, best of luck! 🙂
06-10-2010 11:17 PM
p. sanders,
NI-FGEN is only for the Function Generators, not an M-Series DAQ Card.
F11Raven,
Just open the Express VI called Simulate Signal. It has a 'Add noise' option. If you want to use lower level functions, use the search button on the functions palette to find all of the noise functions.
06-11-2010 08:01 AM
06-11-2010 09:20 AM
06-11-2010 10:03 AM
06-11-2010 10:22 AM
06-11-2010 10:27 AM
Hi F11Raven,
The DAQ Assistant is bundled with DAQmx, which is the driver necessary to interact with your USB-6251. You can download the latest version of DAQmx here. After installing it, you should be able to use the DAQ Assistant within LabVIEW.
06-11-2010 10:27 AM
06-11-2010 01:25 PM
