USB-6421 and LabView 2016?
Hi everyone,
I am using LabView 2016 (for some reasons) and would like to replace the USB-6210 with the new USB-6421 for some projects.
I am not sure if there is a way to install the DAQmx driver that is needed for the USB-6421 and use it in LabView 2016?
The NI table for DAQmx/LabView compatibility says that DAQmx v19.6 is the latest I can use with LabView 2016. I guess that the USB-6421 is not included in this driver version. I could not find the driver requirements for the USB-6421 on the NI website.
Any ideas welcome. Thank you in advance.
LabView 2010SP1, Windows7
(165 Views)
Accepted by hejoba
According to the NI-DAQmx and LabVIEW Compatibility, you will need at least DAQmx 2024Q3.1 and LabVIEW 2021 to use that DAQ. Admittedly, the page needs updated, but the pattern is supporting 3 years back (2024-3 = 2021).
GCentral
(150 Views)
I was afraid of that. Thank you for the clarification.
(119 Views)
