Multifunction DAQ
USB-TC01 and DAQmx
I just bought a NI USB-TC01 device and according to the manual this should be compatible with DAQmx.
I know and see the InstantDAQ feature and it launches a nice small application. But I want to control the
USB TC-01 device from my C++ code using DAQmx, as I do for all my other NI devices.
I can't figure out to do this, since the USB-TC01 device is not listed in MAX.
Please help.
-cpede
(4,467 Views)
Which version of NI-DAQmx do you have installed?  You will need version NI-DAQmx 9.1 Full in order to develop for this device.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(4,463 Views)
I've installed what I believe to be DAQmx 9.2 and my TC01 is not listed.  The logger executable on the device works, and the labview example launches in LV 2009, but does not run - no device found.
Any more ideas?
Mike
(4,107 Views)
I upgraded to NI-DAQmx 9.2.1 and now it is available.  I'm thinking 9.2 didn't install quite right in the first place.
I'm moving on.  Thanks for looking at this for me.
Mike
(4,090 Views)
For others, for future reference, this thread "DAQmx 9.1.1 and 9.2.0 are not compatible with Win7 bit, but 9.0.0 is?" seems like it might be related.  I had updated NI-DAQmx from some older version in order to use the TC01.  That thread has a link to a procedure for correcting a corrupt NI-DAQmx database.
Mike
(4,088 Views)
