06-18-2018 07:41 AM
My USB X series DAQ won't switch on when plugged into mains power. When I press to power on, the active and ready lights on the front flash blue and then turn off. I have used it in this set-up before so don't know why it won't work.
06-19-2018 09:49 AM
Hi louise1,
Does the device appear in NI MAX? If so what does it look like here? Does it pass self-test?
Having a look at the manual it looks like the device is at least initially recognised but perhaps the correct version of DAQmx isn't installed?
You could also try:
Let us know how it goes!
Rebecca
