02-05-2017 10:03 PM
I would like to access the files from the USB plugged on the myRIO USB port through the FPGA but it is not included in the personalities. How can I do this? Thank you.
Also, why are there no blocks relating to sound processing (.wav) when working with the FPGA target VI?
02-07-2017 08:27 AM
Hi studentonproject,
The USB port is actually accessed through the real-time system. The user guide has a diagram on page 3:
http://www.ni.com/pdf/manuals/376047a.pdf
As for interfacing with a flash drive, our myRIO Project Essentials Guide covers using USB flash drives:
http://www.ni.com/tutorial/14621/en/
This includes a link to example VIs that will help you get started.
Cheers,
Ryan
02-13-2017 02:35 AM
Thanks for your reply!
Is there a way to send data from the real-time system to the FPGA?
02-14-2017 09:37 AM
Take a look at this Tutorial. It gives an introduction on how to create an application that communicates between the FPGA and real-time system:
http://www.ni.com/tutorial/52030/en/
Cheers,
Ryan
