10-24-2017 10:25 AM
Hi guys,
This is probably a very simple tuneup, and I wonder if somebody can give tips.
I want to send one continuous saw-tooth way to, say channel 0 of my USB6343, and one continuous sinusoidal wave to channel 1, but both of the the waves should be synchronized by a common external clock, e.g., 32 kHz. NI DAQ does have sample C code for one analog output (Cont Gen Volt Wfm-Ext Clk), but the software stops at DAQmxWriteAnalogF64 when I'm trying to duplicate the same work for the second channel. I guess it is probably only a quick setup of AO parameters.
Many thanks in advance.
John
10-25-2017 12:43 PM
I believe you are only able to do one Hardware time trigger see the solution on : http://digital.ni.com/public.nsf/allkb/2C45C3DC484FF730862570E7007CCBD4?OpenDocument
