USB6363 - Cannot connect terminals?
So I have a VI that uses a master pulse generator and I am using the USB6363 as an AO.  I have set up so that the pulse generator triggers to APF1 and mirrors it to ao/StartTrigger, but I get the following error
DAQmx Connect Terminals.vi:4600001<append>
<B>Source Device: </B>Dev4
<B>Source Terminal: </B>APFI1
<B>Destination Device: </B>Dev4
<B>Destination Terminal: </B>ao/StartTrigger
Not sure what that means or why this is happening.
(3,395 Views)
Hi jmaslek,
could you please post the code?
(3,373 Views)
I encountered the same problem. Do you remember how it was solved at the time?
Thanks.
(2,370 Views)
From what I recall, the computer just needed to be restarted and daqmx reinstalled.
(2,364 Views)
