Multifunction DAQ
Unable to work with qDAQ-9172 due to Status Code: -209852 The specified device is no longer supported
Dear members,
When trying to connect to my older NI cDAQ-9172 I got following error:
The specified device is no longer supported within the NI-DAQmx API.
Visit ni.com/info and enter the Info Code: Cseriesdoc
When I go check this sit I get following text:
cDAQ-9172
Minimum Software Support
Software CompactRIO (FPGA Interface) RIO Scan Interface NI-DAQmx EtherCAT (FPGA Interface) EtherCAT (Scan Interface)
7.0 to 2017
LabVIEW FPGA Module
LabVIEW Real-Time Module*
Device Driver Software
NI-DAQmx 8.1 to 17.5
Other Minimum Software
Notes
*  Refer to the DAQmx Readme for LabVIEW Real-Time Supported .
•  LabVIEW Real-Time Module is only required if the cDAQ Controller is running a Real-Time Operating System.
•  Refer to NI C Series Module Compatibility Chart for more information on supported modules.
First of I installed the newest version of Labview which I have 2017 and Device drivers 17.5, they didn't work. So I thought that maybe by saying to 17.5 they meant that 17.5 in not included. But now that I installed 17.0, I still get the same error
Does anybody know how to fix this error or what I should do to get this fixed?
Thank you in advance.
Best Regards,
Bart
(4,927 Views)
That's the version of Measurement and Automation Explorer, not the version of NI-DAQmx.
To get the version of NI-DAQmx, open the "Software" dropdown in the treeview and look for "NI-DAQmx Device Driver".
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(4,911 Views)
Thank you for your explanation. This already makes it more clear to me.
My question now is if I/we can install older drivers so that my older cDAQ-9271 is also suported by this version of MAX or do I really have to install a way older version of MAX?
Best Regards,
Bart
(4,890 Views)
Accepted by topic author Bart_Aerts_KUL
Newer versions of MAX are backward-compatible with older versions of drivers.
In other words: if you install NI-DAQmx 17.5, and then a newer version of some other driver-- which in turn may require a newer MAX-- then that newer MAX will still work with the older NI-DAQmx.
Brandon Streiff
(4,887 Views)
