05-18-2012 04:01 PM
I am using the DAQ assistant to input an analog voltage from a NI data acquisition board. What is the difference between the number of samples and the rate in the DAQ assistant and what are the units of both?
Thanks.
05-18-2012 04:47 PM
The number of samples is how many discrete measurements to make. The rate (per second) refers how fast to acquire the specified number of samples.
If number of samples is 100 and the rate is 1000 samples/second, then the acquisition would take 0.1 seconds (100 / 1000).
-AK2DM
08-21-2013 01:23 AM
May I know the difference between the 2 following cases:
Case 1 : sample to read = 5000, rate =5000, then the acquisition is 1 second
Case 2 : sample to read = 100, rate = 100, then the acquisition is 1 second
Thank you
08-21-2013 02:31 AM
08-21-2013 03:29 AM
Thanks for the reply.
But is the acquisition the same?
I try to measure voltage waveform and display on chart.
Is this means that there be value output every one second?
Hope for guidance. Thank you.
08-21-2013 03:41 AM
