I Just installed a PCI-MIO-16E-1 (6070E) card in my PC and I am trying to output a sine wave. Right now I am just using measurement & automation explorer to do some testing and having trouble generating higher frequency sine waves. The sample rate is set at its maximum specified setting of 1Ms/S for output, I am trying to generate a sine wave of 100kHz by setting the "Samples to read" to 10. With these settings no output appears on the channel I am trying to use. The lowest I can set the "samples to read field" seems to be 15. Any advice or are there other settings I should be adjusting to get a reliable 100kHz signal?
