Multifunction DAQ
Why a floating signal is less than 1V cannot be measured by RSE mode?
In "Field Wiring and Noise Considerations for Analog Signals", it is said
  • Input signals are high level (greater than 1 V)
  • Signal cabling is short and travels through a noise-free environment or is properly shielded
  • All input signals can share a common reference signal at the source
Differential connections should be used when any of the above criteria are violated.
I would like to know that my signal is about 100-600mV (it is a floating signal), and whether is can be measured by RSE mode?
Thands advance!
Message 1 of 1
(2,825 Views)
