In "Field Wiring and Noise Considerations for Analog Signals", it is said
- Input signals are high level (greater than 1 V)
- Signal cabling is short and travels through a noise-free environment or is properly shielded
- All input signals can share a common reference signal at the source
Differential connections should be used when any of the above criteria are violated.
I would like to know that my signal is about 100-600mV (it is a floating signal), and whether is can be measured by RSE mode?
Thands advance!
