cDAQ 9171 Calibration Verification
We're trying to evaluate the calibration verification requirements of an cDAQ 9171 USB Single slot chassis.
We're using a cDAQ 9171 to take some simple +/- 5 volt readings using a 9205 analog input module.  The 9205 has a specific calibration/verification manual for voltage measurements, no confusion there at this time.
This article has a general verification process for cDAQ Chassis which focuses on a Digital Input module.  Is this something that's going to affect the analog voltage signals we're picking up?  Is there a way to verify calibration using the module we already have?  Or is the 9205 calibration process the only one that's relevant to our simple voltage gathering setup?
(4,088 Views)
Accepted by aaspersl
The calibration of the chassis is only for digital I/O. Therefore I don't believe it will affect the analog readings. The module calibration should be the only one that is relevant for analog tasks.
Mathew H.
Applications Engineer
(4,052 Views)
Thanks for the clarification, that's exactly what I needed to know!
(4,018 Views)
