Multifunction DAQ
cDAQ AO to AI
Hey everyone,
I'm currently trying to read in 4 AI channels and output 1 AO signal. For my application, the timing of the AO in relation to the AI is of importance. TO be sure, I would like to record the output AO signal. Is there a possibility to record that AO signal somehow internally with out doing a hardware loop?
I am using a cDAQ-9178 with a 9215 and a 9263 module in it for this purpose.
George
(3,867 Views)
Accepted by Der_schorsch
Hi George,
if you have an AO you can´t use this as AI at the same time.
In the example data base in LV you´ll find an example for voltage - continuous output. ( help --> find examples --> HW Input and Output --> DAQmx --> Analog Output)
You can see, that the AO signal is shown in a graph there.
Instead of the graph you could also use an array or something else.
Hope this was helpful.
Nina
(3,685 Views)
