02-28-2013 03:51 PM
What are the differences between the real time version of cDAQ stand along and cRIO? The concepts sound pretty similiar to me. Pro and Con for each?
03-01-2013 04:32 PM
Hello jyang,
As far as the Real-Time version of Stand Alone cDAQ and cRIO, they should be the same. You install LabVIEW, then LabVIEW Real-Time, then the drivers (NI-DAQmx for the cDAQ and NI-RIO for the cRIO).One noticeable difference between both platforms is that cDAQ can use the DAQmx drivers, and Real-Time capabilities. However, you will NOT be able to use LabVIEW FPGA, as the Stand-Alone cDAQ lacks FPGA. I would also mention the criteria that you want to have when choosing FPGA over DAQ, like if you want to have dozens of counters, true parallel tasks, or reconfigure you I/O.
