Multifunction DAQ
can I connect the analog outputs of a DAQ in series configuration to have higher voltage source?
Hello Guys,
 My question is provided in the topic, do you have any idea regarding taht? your help is appreciated.
Ela
(3,632 Views)
Accepted by topic author elahetal
Hi Ela,
For almost all of the devices supported by DAQmx, you cannot. When all of the AO channels have the same ground, connecting them in series would short the channel outputs to ground, which is bad.
However, there is an exception: the SCXI-1124 module has channel-to-channel isolation, which allows the channels to be cascaded to output higher voltages.
With channel-to-earth isolated devices (such as the NI 926x or NI 623x), you may be able to cascade multiple devices together, but not multiple channels on the same device.
Brad
Message Edited by Brad K on 01-19-2010 07:28 PM
Brad Keryan
NI R&D
(3,626 Views)
The NI 9269 has channel-to-channel isolation, so we can cascade multiple channels on the same device: https://www.ni.com/docs/en-US/bundle/ni-9269-getting-started/page/overview.html
Certified LabVIEW Developer
(3,207 Views)
Hi JKSH,
Thanks for pointing out that the SCXI-1124 is no longer the only DAQ AO module that supports cascading multiple channels. In addition to the NI 9269 that you mentioned, which supports cascading 4 channels to output +/-40 V, the NI PXIe-4322 supports cascading 8 channels to output +/-128 V.
Brad
Brad Keryan
NI R&D
(3,187 Views)
