04-19-2010 11:45 AM
04-19-2010 11:57 AM
Are you using NI-DAQmx to communicate with the USB TC-01 or are you using the built in temperature logger?
04-19-2010 11:59 AM
I am using the built in temperature logger.
Cheers!
04-19-2010 12:13 PM
The built in temperature logger is preset to sample once a second. If you need more time between samples, you'll need to use an Application Development Environment (such as LabVIEW, LabVIEW SignalExpress, or Visual Studio) to write a program that samples from the USB TC-01 once a minute and then writes it to a file. There are some examples on the Do More with Your NI USB-TC01 Community Group that can help get you started.
Hope this helps!
07-08-2010 07:55 AM
I would like to acquire 2 samples per second instead of 1, as done by the built in data logger. I am currently trying to do so using labview. In the DAQ assistant configuration window, I tried to change the acquisition mode in the timing setting from "1 sample (on demand)" to "one sample (HW timed)" with 2 Hz as a rate. However, this action is refused by DAQ mx and the error report says that only "on demand" is possible. Then how can I modify the sampling rate from 1 Hz to 2 Hz?
Thanks in advance,
Charly
07-08-2010 09:30 AM
You've got your DAQmx Read/DAQ Assistant in a loop, right? Just use a Wait or Delay function set for .5 seconds.
07-08-2010 09:53 AM
Thank you that was indeed very simple!
