Something happened to my previous response??
Thanks for the Info, now I know that IEPE and 4-20 mA power loop are not the same, and I found another page that explains the concept much better:
http://www.endevco.com/Our-Resources/Ask-the-Experts/Understanding-IEPE-accelerometers-vs-4-20-mA-se...
I cannot post the visual basic code, but I will ask the author about it, but he's probably using it as an accelerometer and integrating it twice via software, although, I will ask him and update in here.
And even if they are different, I can select the IEPE source to power up these piezoelectric sensors, and they will work fine (cannot use AC or DC sources on them)
Attached is an image of the program that I'm doing (using velometers)
![prg.png prg.png](https://forums.ni.com/t5/image/serverpage/image-id/315848iC56B175E7CBDB86E/image-size/medium?v=v2&px=400)
this is a little motor that I'm testing:
![setup.png setup.png](https://forums.ni.com/t5/image/serverpage/image-id/315849i21FFA105C7EF965C/image-size/large?v=v2&px=999)
so... my question remains, do displacement piezoelectric sensors have a specific notation or should I treat them as accelerometers or velometers?
