08-27-2008 07:44 AM
HelloI
This is the first time for me to use the LabView, as I want to use the DAQ USB 6008, my problem as the follow
First of all the circuit am working on consist of MUX and operational amplifier , what I want to do is to read the output voltage from the OP/Amp via the USB 6008, and send the MUX address using the USB 6008, I can use the LabView to read the voltage, but I don’t know how to use the trigger as I want to read the output voltage from the op/amp for each channel of the MUX per time, and how can I use the trigger also to send the MUX address at the same time.
am using labview 8.5
Hope to help me
Thank you all
08-28-2008 05:46 AM
Hi Ghadeer,
Unfortunately, the 6008 does not support digital triggering or clocked ouput. You would have to implement software timing along with your analogue input to try to synchronise the two operations, although there would be a limit on the maximum speed that you're able to achieve with the digital output.
