how long to get simple multifunctoin DAQ going in Labview?
i am trying to do some simple, slow digital and analog i/o. about 5 channels total, 1 second update rate is fine.
i tried connecting an Arduino to Labview / PC but could not get things working.
i am thinking of using something like the USB-6001, want to read / write a few pins from within Labview.
have some experience with Labview -- file i/o, plotting, etc.
would i be able to get running with this USB-6001 within a few hours?
any suggestions appreciated.
michael cohn
(4,230 Views)
 If you still would like to try this with and Arduino I would suggest trying LINX toolkit.
Here is a good starting point for DAQmx which is the driver for that DAQ. Also if you have LabVIEW check the example finder under Hardware Input and Output>>DAQmx. This instrument has multiplexed inputs due to a single ADC so your measuments will not be simultaneous.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,218 Views)
thanks govbob!. i will check this out.
mc
(4,212 Views)
Accepted by michaelbcohn
My current record is 20 minutes on a cDAQ while explaining the program to a novice and pulling the hardware and sensors from stock.  Yes, I started from the Contineous Measurement and logging (DAQmx) Project Template.  Room temp was 19C on average from 3 sensors and my Armpit read 37C-  I no longer have access to the server where the data was logged.
Any USB DAQ would be just as easy
"Should be" isn't "Is" -Jay
(4,197 Views)
thanks jeff, that is what i needed to hear.
mc
(4,191 Views)
