in NI-DAQmx 9.1.0 DAQmxGetDevAIMinRate returns zero for some CompactDAQ devices
In NI-DAQmx 9.1.0 several devices began reporting that their minimum AI rate is zero.
The same devices report a non-zero rate in 9.0.2.
Two devices of interest are NI 9201 and NI 9205 but there may be others.
The attached program outputs the NI-DAQmx rev, device ID and Device Type.
For 9.02 we get:
Running on NI-DAQmx 9.0.2
Using CDAQ1Mod1 : NI 9201 - minimum rate is 0.000023283
Using CDAQ2Mod2 : NI 9205 - minimum rate is 0.000023283
For 9.1 we get:
Running on NI-DAQmx 9.1.0
Using cDAQ1Mod1 : NI 9201 - minimum rate is 0.000000000
Using cDAQ1Mod8 : NI 9205 - minimum rate is 0.000000000
The results on 9.1 are identical for real hardware and simulated devices.
The question is - how do I get the actual minimum rate in 9.1.0?
Thanks!
Sherryl Radbil
Data Acquisition Engineer
The MathWorks
(2,844 Views)
Hello Sherryl,
Thank you for bringing this to our attention, it looks like this is a bug.  I've filed CAR #221457 to address this issue.
As far as a workaround, the only one I could think of was query the timebase rate and the min rate would be timebase/2^32.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(2,832 Views)
