In NI-DAQmx 9.1.0 several devices began reporting that their minimum AI rate is zero.
The same devices report a non-zero rate in 9.0.2.
Two devices of interest are NI 9201 and NI 9205 but there may be others.
The attached program outputs the NI-DAQmx rev, device ID and Device Type.
For 9.02 we get:
Running on NI-DAQmx 9.0.2
Using CDAQ1Mod1 : NI 9201 - minimum rate is 0.000023283
Using CDAQ2Mod2 : NI 9205 - minimum rate is 0.000023283
For 9.1 we get:
Running on NI-DAQmx 9.1.0
Using cDAQ1Mod1 : NI 9201 - minimum rate is 0.000000000
Using cDAQ1Mod8 : NI 9205 - minimum rate is 0.000000000
The results on 9.1 are identical for real hardware and simulated devices.
The question is - how do I get the actual minimum rate in 9.1.0?
Thanks!
Sherryl Radbil
Data Acquisition Engineer
The MathWorks
