measure temperature from YSI 44100 thermistor using 1314 into a 1520 module
I am trying to wire up a YSI 44100 thermistor into a 1520 module through a 1314 terminal block.  I have tried various ways of plugging the thermistor in, but have not yet received what I think is a good signal into labview.  How should I wire the thermistor into the 1314 terminal block?  I have attached the thermistor's data sheet.
Thanks for any help.
(2,732 Views)
Hi pjlefeb,
The SCXI-1520 supplies voltage excitation, where a thermistor needs current excitation.  The SCXI-1503 and SCXI-1120 can be used for thermistor measurments.
h_baker
Applications Engineer
(2,709 Views)
