ni 6343 differential channel limit?
Hello, I'm having a problem with the NI USB 6343. I know this hardware supports 16 differential channels, however, when I try to use in in MAX (ver 5.6.0f0) I can only select the first 8 channels as differential. From channels 8 on the differential drop down is greyed out. This happens in test panels, as well as when I create a DAQMX task.
**Update**
Nevermind, I didn't realize you couldn't go in exact channel order.
Diff channels are 0-7 and 16-23
(3,448 Views)
Thanks for the update! I was already researching about it! (Y)
Randy @Rscd27@
(3,422 Views)
