12-27-2010 08:02 AM
Hi, I have a problem when I launch my VI to acquire two signals from a lock in amplifier. When the VI is off, the signal on the oscilloscope is clearly clean and good but when I turn on the VI on the oscilloscope the signal becomes very dirty and noisy. I already tried to change reference connections but nothing happened.
Could anybody give me a help?
12-28-2010 04:12 AM - last edited on 05-02-2024 05:44 PM by Content Cleaner
Hi NICC,
I Don't know the output parameters of your source, so I can't know what could be the cause of this unexpected behavior.
Anyway, I suggest you to read the chapter 4 of the device manual, that you can find at the following address:
https://www.ni.com/docs/en-US/bundle/pci-pcie-pxi-pxie-usb-62xx-features/resource/371022l.pdf
Have a great day!
12-28-2010 09:51 AM
The 6251 is a multiplexed board. If you're using an external oscilloscope, you're probably picking up the transitions of the multiplexer. Ideally you'd want to wait for the channel to settle before taking a sample.
Best Regards,
12-29-2010 04:40 AM
Thank you for your replies, but I wonder why the same signal is not noised when I use a usb9162. Anyway I try to apply some of your tip
12-29-2010 02:02 PM - last edited on 05-02-2024 05:46 PM by Content Cleaner
You didn't mention the 9162 before, but this is actually just the model number for the USB C Series carrier. The front-end behavior is going to depend on what module you are using with it. For example, modules like the 9215, 9237, and 9229/9239 are simultaneously sampled and wouldn't have the same behavior. Modules like the 9201 and 9221 are multiplexed like the 6251.
Best Regards,
