03-14-2011 10:48 AM
Hey there everyone,
i'm working with the following setup:
- PXIe-1062Q (Chassis)
- PXIe-8108 (Embedded Controller)
- PXIe-6361 (Card used for signal generation)
- PXI-6133 (Card used for measurement purposes)
- 2x PXI-6509 (not yet implemented)
The system is connected via ethernet and i'm trying to generate two simultaneos free waveforms with the AO-0 and AO-1 Outputs from the PXIe-6361,
they should start at nearly the same moment.
Also it has to be possible to change amplitude, frequency, phase and waveform on the fly.
A trigger signal should be generated every period so that the measure card "knows" when a period starts. I thought the RTSI-Bus would be well suited for this signals.
I don't want you to solve all these Issues but i seriously need a good approach to solve them, because i'm trying it sice one week to get simultaneous glitch free waveforms and it just will not work...
Thanks in advance
Kai T.
BM_Trainee
03-16-2011 05:26 AM
UPDATE:
Hello again,
now it's possible to generate two simultaneous Waveforms which are independent according to amplitude and phaseshift. The frequency for both signals should be exactly the same so i got it wrong in the my first post.
As you'll see in the following pictures, everything works fine, besides one big problem:
Figure 1: General Output
Figure 2: 180° Phaseshift
Figure 3: different amplitudes (1.5V and 0.5V) V/div are the same as before!
The problem i has been talking about are the pauses between each 1000 samples.
Also i have to stop the output-task so that i'm able to generate a new wave.
I have to generate Signals up to 7 kHz and maybe higher. When i tried to get this output the system crashed.
I'll just attach the whole project to give you a better insight in my actual program.
So my question is, can i somehow use a continuous sampling mode and update the values to be generated on the fly?
I think it should be possible by using the onboard DAC-FIFO but i don't know how i can utilize it.
Thanks in advance
Kai T.
BM_Trainee
03-28-2011 08:52 AM
Hi BM_Trainee,
I found these two examples, perhaps this will help:
1. http://decibel.ni.com/content/docs/DOC-7692
2. http://decibel.ni.com/content/docs/DOC-3457
Best Regards,
Lam
