05-01-2013 02:05 PM
Hi all,
Has anyone tried making a wireless bidirectional UART port out of a CompactDAQ device? It looks like the 9401 module is fast enough for my baud rate (115k) but from what I've read about UART, there is an oversampling and synchronization protocol that needs to be run regularly to keep both ends of the connection in sync. I don't yet have the device, so before I buy one any feedback would be much appreciated.
thanks,
George
05-02-2013
09:44 AM
- last edited on
05-08-2024
10:11 AM
by
Content Cleaner
Hi gharris,
The CompactDAQ platform is not designed to operate as an embedded system with hardware-timed control, such as is required by UART. Essentially in a WiFi CompactDAQ system, your raw digital data would be acquired by the 9401, streamed over WiFi, and received by your PC where you would then process the bits in software and create a response that would be sent back to the CompactDAQ system. This control loop would not meet timing requirements.
There are two options you may want to consider that will allow wireless control of serial:
These are the best approaches for what it sounds like you want to do.
