Multisim and Ultiboard
Frequency counter not working
i'm trying to measure the frequency of the 555timer's output but it does't work.
but ocilloscope works well...
is this bug? or i do something wrong?
(2,267 Views)
Accepted by topic author indusk9912
Привет, Индюк!
Покрути настройки как на GIF-ке. Должно сработать.
(2,249 Views)
What does the two potentiometer do? Can I do only one potentio(the one in the middle)?
(2,178 Views)
Спасибо за звезду!
Для вас всё можно!
(2,168 Views)
Hi ALL,
I have the same problem trying to measure the frequency, of approximately 92 kHz square pulses, generated by a 555 timer. I use Multisim V-14.2 and XFC1 counter. This counter works well with 120Vrms/60Hz source. It measures frequency and period but does not work with 1V/1kHz and/or any other square pulse sources such as 1 kHz/5V or even with 1Vpk/1kHz AC source. Thanks for the help in advanceFreq,Cntr..jpg
(772 Views)
